跳转到主内容
加入维修社区 - 创建账户
Fairphone 手机的第五代产品,由同名社会企业制造。发布于2023年9月。
NFC chip replacement query
My NFC chip is faulty. I've done all the tests including the onboard hardware ones, but no success, so time to replace if I can.
does anyone know where it's located and if/how I can swap it out?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hello,
Just a sanity check first,
  • did you run the test with a NFC card you know has worked in the past, and / or works with another phone?
  • update the OS, and reboot the system (sometimes android fails to initialise NFC)
  • re-seat the battery to re-seat the NFC antenna?
The Fairphone 5's NFC antenna is a built-in part of the battery, (pins 3&4 on the battery connector.)
so you are able to swap out the antenna by swapping out the battery.
But the actual chip itself is soldered to the main board and is not designed to be user serviceable without considerable skill and tooling
the schematics list it on page 40 as U3902 and on page 76 as ST21NFCD/ST54F
Your best bet to restore this functionality is to contact Fairphone support directly and ask about a warranty repair
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Andy Wilkins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 73
总计 517
