跳转到主内容
加入维修社区 - 创建账户
Why is flashing the light
When I. Open the door the light starts flashing
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
2条评论
Jacob, can you include the model number of your refrigerator?
由完成的
For sure Jerry dff100c1wdb
由完成的
添加一条评论
1个答案
已选择的解决方案
Hi @jacobarenas
Check if the evaporator unit inside the freezer compartment at the back behind a panel (access to the panel is though the door at the front) is iced over.
If it is then there's a defrost problem with the refrigerator.
This could be due to a faulty defrost heater p/n C1414.4.3, a faulty defrost thermostat (aka thermal fuse) p/n C0472.4.4/BD, a wiring problem for the defrost circuit, a faulty defrost control board or the drain tube leading from below the evaporator unit in the freezer to the drain pan underneath the compartments, near the compressor may be blocked.
Let us know what you find.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Jacob Arenas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 31
总计 577
