跳转到主内容
加入维修社区 - 创建账户
Acer TravelMate 是宏碁于 1997 年推出的商务笔记本电脑系列。TravelMate B115 型号于 2014 年推出。
Device ran into problem
Everytime I try to turn on my laptop, it's Acer TravelMate B117 by the way. But when ever I try to turn it on, I get a blue screening saying something like "device ran into a problem :(" and then it asks me to restart, when I click restart it just goes into alot of loading screens and goes back to the same screen that says " device ran into a problem:("
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi @abdelabdramane
If Win10 is installed in the laptop try the following and check if it resolves the problem.
Turn on the laptop and when it boots into Windows, press and hold the Power button operated until the laptop shuts down.
Do this 3 times in a row i.e. Start >boot > force stop >start > boot > force stop > start > boot > force stop etc.
On the 3rd attempt it should boot int the Windows Recovery Environment menus.
If it does when in the WRE menus, select Troubleshooting > Advanced > Startup repair and follow the prompts.
If it doesn't get into the WRE menus, create a Windows recovery USB disc. You can create the recovery disc from any known working Win10 PC. All you need is a 16GB USB flashdrive and 1-2 hours of time. In the host PC go to Control panel > Recovery > Create a recovery disc and follow the prompts.
Once you have the USB recovery drive, insert it into the laptop and start the laptop and then quickly press F12 and change the boot order to USB as the 1st boot option.
The laptop should boot from the USB drive into the WRE menus. Follow the procedure as outlined above.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abdel Abdramane 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 34
总计 293
