跳转到主内容
加入维修社区 - 创建账户
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
iPhone 5 LCD separating from frame.
I tried to replace the battery on an old iPhone 5 that i have but the LCD separated from the frame, despite removing the two pentalobe screws. Anyone know how to prevent this from happening again and how to pry off the remaining part.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You haven’t put your opening tool into the screen incorrectly. Put it between the plastic frame and the metal body then pry it up gently. Do the same around the frame except the top which is located by tabs. If the screen still works after you get it out buy some B7000 adhesive to fix the screen back together.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Henry 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 134
