Why wont my jeep start
points and condenser have been replaced the coil too but when turning over there iis no fire power to the coil
Susan Luntsford, you did not tell us if it is stock or if it is a mod jeep. Engine Size and mods are important since it does make a difference. If you have no power to the coil, check your ignition switch. Make sure the switch close the circuit to the ignition coil. Check the wiring from the positive terminal of the battery to the switch, make sure it is connected and not shortened out. If it worked before, but stopped working since you replaced the parts, double check your work.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 0
过去的30天: 2
总计 3,008
