跳转到主内容
加入维修社区 - 创建账户
小米 Poco F5 发布于 2023 年 5 月 重 181 克,厚度 7.9 毫米 Android 13,最高可升级至 Android 14,搭载 HyperOS 256GB 存储空间,无存储卡插槽
How to replace lcd?
how to replace lcd
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
This isn't really important, but just as a point of order before we start, your phone technically has an OLED display, not an LCD. Those are two very different technologies, with the OLED being newer, with higher resolution and uses less power.
Anyway, with your phone, like several Android phones, there are two ways to do a screen replacement. The first is to remove the screen by itself. This involves taking out the battery to access the display connector, then peeling off the connector from the phone's midframe, and finally separating the OLED display from the midframe. You then have to clean off the old adhesive, replace it with a sheet of precut adhesive or use some glue such as B-7000. This video shows the steps and procedures involved.
Poco F5 Screen Replacement - YouTube
The second method is a completely different procedure in which you purchase the screen already mounted to the midframe. That alleviates the issue of separating the old screen, cleaning it and regluing it, but it means you basically have to gut the phone and move all of the interior components to the new midframe. Generally I've found that the cost of the screen+midframe assembly is only a few dollars more than the screen alone; you often make that up when you have to buy glue. This is generally the preferred and safer procedure, but which one you use is up to you. Here's a different video showing the second technique.
POCO F5, habis jatuh,lcd nya pecah, begini cara ganti lcd nya, yuk simak proses ganti lcd poco F5 - YouTube
My apologies that neither of these is in English, but the one I found that was, wasn't of good enough quality that I could recommend it. Generally you don't need audio to follow along anyway.
这个答案有帮助吗?
得分 1
添加一条评论
Hi @keygaminghs
Here's a video that shows how to replace the display.
Depending on how much you need to replace, search online for either Poco F5 display module LCD + digitizer or Poco F5 display unit complete to find suppliers that suit you best. (supplier examples only)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Key Gaming Hs 将永远感激不已
浏览统计数据:
过去 24 小时: 14
过去 7 天: 22
过去 30 天: 76
总计 1,473
