跳转到主内容
加入维修社区 - 创建账户
Ninja Foodi SP101 是一款数字空气炸锅,兼具空气炸锅、多士炉和热风烤箱的功能。
How to Remove Side Panel?
I have been struggling to get the side panel on this removed. I am aware the guide here says to unscrew the 3 screws and then push the panel towards the control panel until the clips are visibly detached
However I have not been able to produce this result with varying levels of force. There is something towards the control panel that is firmly holding that side of the panel in place no matter what I try.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
It works with light force, so there's probably still a hidden screw that needs removal. For me, it was the TR10 (security Torx) on the inside left front wall middle near the door, covered in grease. So in total you remove the black plastic bar screws, the back panel screws on the side you want to remove, and the screws underneath the bottom flip tray on the side you want to remove.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Luke Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 21
过去 30 天: 63
总计 345
