跳转到主内容
加入维修社区 - 创建账户
雅马哈发动机株式会社制造的摩托车的维修指南和技术支持。
solenloid decompression problem. Solved!
Road Star XV 1700 2006, solenloid pushes the two rods in, but valve does not stay open to decompress. Anyone an idea ? Cheers. Two days later : After opening up the crank-carterI, I found one of the two rod- levers was slightly bent, so it didn't push in the decompression-rod enough to engage the extra crank-opening-moment of the exhaust-valve.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
So if changing the starter-motor, start-relay and decompression-solenoid don't resolve the problem, take out the engine oil, then take of the crank-carter and check if the two rod-levers push both rods in ( equally ).
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kees van schaik 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 20
总计 411
