跳转到主内容
加入维修社区 - 创建账户
2008 年发布的 HP 台式机。
Window 7 sound not working problem
Update (05/22/25)
Window 7 sound not working problem solution
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  • Check Audio Settings
    • Right-click the speaker icon in the taskbar and select Playback Devices.
    • Ensure the correct audio device is set as default.
  • Update or Reinstall Audio Drivers
    1. Open Device Manager and locate Sound, Video, and Game Controllers.
    2. Right-click the audio driver and select Update driver.
  • If updating doesn’t work, uninstall the driver, restart the PC, and let Windows reinstall it
  • Check Physical Connections
  • If using external speakers or headphones, test with another device or port to rule out hardware failure.
  • Download Drivers from HP Support
    • Visit HP Support and search for HP a6500f to find compatible audio drivers for Windows 7.
    • Install the driver, restart your PC, and test the sound output.
  • If none of these steps resolve the issue, consider testing with a Linux Live USB to determine if it's a hardware or software problem. Hope this helps!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dipanshu 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 16
总计 247
