My headset mic is not working
My headset mic is not working. How can i fix it?
Not sure what’s going on, but maybe check if your headset is set as the default input device in sound settings. Sometimes just unplugging and plugging it back in helps too.
If that doesn’t work, try it on another device to see if the mic itself is okay. Could just be a settings thing or a small driver glitch.
这个答案有帮助吗?
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 48
总计 963
I have the same issue. Tried my Evolve 2 75 headset on many devices, the mic is not working.
由 Christy Erasmus 完成的
Same too, mic stopped working yesterday on laptop and phone.
With diagnostic tools I can see some electric noise generated when physically moving the mic stick up or down.
由 A. Matías 完成的
I had same issue. and I downgraded my heaadest version 1.7.4. all is working now. Mic started to wroking again.
For some other users 1.6.0 version works fine and there is no mic issue too.
My previous version was 1.12.10.
https://www.simplyheadsets.com.au/blog/t...
https://www.reddit.com/r/Jabra/comments/...
由 Sahin 完成的
I had the same issue with the mic not working at three devices so far. There is a smal wire going through the pcb wiche grinds down over time and interrupts the connetion. To fix it you have to open the device and replace the wire. There are many videos on YouTube how to do it. This for example https://www.youtube.com/watch?v=OcYFOJ0A...
由 Marvin H 完成的
