跳转到主内容
加入维修社区 - 创建账户
Murray® 22 英寸 2 合 1 前轮驱动自走式汽油除草机,配有 140cc Briggs & Stratton® 发动机
No drive to wheels
Change the drive belt
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
The front wheel drive stopped working on my Murray 22 inch front drive mower. I couldn't get the cover off the wheel drive. I took off two big and two small screws underneath but the cover would not come off so I took off the blade, removed the 3 nuts on the engine pulley cover, found the belt slipped off the engine pulley. I took off the pulley, watch for the Woodruff key, kind of a trick to get it back into the engine pulley. The belt looked okay. The side of the plastic engine pulley may have to be replaced but I put the belt back on. Reassembled and it worked okay but I will eventually have to get the drive cover off and replace the belt. Any help here?
Jerry in Kentucky.
完成的
添加一条评论
1个答案
Here's a page from the manual that might help. Good luck.
En 2a8a513128c1d33166c65ab81a984af2
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dennis schweitzer 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 14
过去 30 天: 68
总计 585
