跳转到主内容
加入维修社区 - 创建账户
Craftsman 900.370510 是一款重量为 52 磅(约 23.6 公斤)的电动割草机,工作电压为 120 伏,电流为 12 安培。它具有 19 英寸(约 48 厘米)的切割宽度、可调节的切割高度,并配有折叠式手柄,便于紧凑存放。本页面包含有关该产品的维修指南及详细信息。
How to clean the mower deck
My mower won't start, how do I clean the mower deck
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Personally, I use a pressure washer to clean the underside of the deck. You can turn the mower on its side and either use a pressure washer, or (as I did in pre-pressure washer days) use a gasket scraper or putty knife to scrape the underside of the deck. If you'd rather not turn the mower on its side, placing it up on two inverted 5 gallon pails should give you the clearance to get under there with your putty knife.
As for the starting problem, presuming this is a 120 volt plug in mower, a clogged deck could prevent starting. Short of that, be sure the plug is tight in the outlet and that there is power to the outlet.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cookiechu 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 131
