跳转到主内容
加入维修社区 - 创建账户
Craftsman 137.218072 是一款配备 10 英寸锯片的台式锯,支持最大 24 英寸的纵切,并在 90 度角下拥有 3 英寸的最大切割深度。本页面提供了关于该产品的维修及其他信息,包括其 5000 rpm 电机、锯片防护罩、分料刀、斜切规等部件。
Table saw stopped working
This Craftsman saw has not been used in four plus years sitting in a shed. I turned it on with an extension cord and it fired up for about 2 seconds I unplugged extension cord I tried to plug it back in and it will not turn on. I know there's a reset button and I try to push it but it won't work. Any suggestions
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Always best to start with the basics. Here's the manual for your saw; there's a troubleshooting section that I copied below as a place to begin.
Craftsman 137218072 table saw manual
PROBLEM
Saw will not start.
POSSIBLE CAUSES
1. Saw is not plugged in.
2. Fuse blown or circuit breaker tripped.
3. Cord is damaged.
4. Debris in on/off switch
CORRECTIVE ACTION
1. Plug in saw.
2. Replace fuse or reset circuit breaker.
3. Replace power cord.
4. Remove switch from saw and separate in half. Clean any debris accumulated within.
Check their suggestions then come on back and let us know what you find and we'll go from there. Do you have a volt meter and know how to use it?
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Sean Davis 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 16
总计 240
