跳转到主内容
加入维修社区 - 创建账户
型号 A1502 / 2.6 GHz(睿频最高可达 3.1 GHz)或 2.8 GHz(睿频最高可达 3.3 GHz)双核 Intel Core i7 处理器,配备 4MB 共享三级缓存。
Fix keybord cable before replacement
I need to replace the keyboard of my MBP because sone key stopper working and I think it’s because the connector is damnaged. Before proceed, I’ve searched here some similar questions and found also one where there is an attacched video with the needed steps. I’m looking for a written guide I can follow, but my question is, can I fix only the connector instead of replacing the whole keyboard? To do the fix I need to remote the battery and display or I can avoid? If I Remo e the battery how I will put it in place again, is there a special take I can found on Amazon that I can use?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I have made written guides for many models but ifixit has yet to approve them.
MacBook Pro 13" Retina Display Early 2015 键盘更换
You'll have to remove the battery to change the keyboard, as the keyboards cable is part of the keyboard, and also to get to the track pad and it's cable, I would check this cable 1st as it is replaceable, check to re connect it 1st. and also any think double sided tape should be strong enough to hold the battery in its place again afterwards.
这个答案有帮助吗?
得分 2
2条评论:
The 2015 model have sone differences with the mid2014?
完成的
@ziobru The exact guide for the 2014 model has yet to be published by ifixit. It is the virtually same procedure anyway.
完成的
添加一条评论
添加你的答案
B1P 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 29
总计 284
