跳转到主内容
加入维修社区 - 创建账户
惠而浦(Whirlpool)双开门、底部冷冻柜抽屉、带有制冰与饮水分配功能的冰箱。
Fridge getting too cold
I set the fridge temp to 38, monitored with separate thermostat. The range was 28-31 degrees. Freezer compartment is set to 0 and range is 3-8 degrees. Questioning if it’s the control board or the thermistor? Thanks.
Model #wrx735sdhz01
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @kory71250
Here's the tech sheet that may help.
Run the diagnostic mode, Service tests 1 & 2 as described to check if both of the temperature thermistors pass or fail.
If they pass it doesn't mean that they're OK, it just means that they're not open circuit or short circuit.
The resistance values of the thermistors at selected temperatures are shown in the tech sheet, so you may have to measure them with a DMM (Ohmmeter function). You can either disconnect the P5 harness plug from the control board and measure back from there to each of the thermistors (P5/1-2 refrigerator, P5/3-4 freezer) or disconnect each thermistor from the harness cable and measure them there. May be better at the control board end, as you don't have to open the refrigerator and lose cool air from each compartment that may alter the temp. Disconnect the power from the refrigerator before trying this.
If both thermistors seem to be OK (with 5% anyway) it may be a control board problem.
Not quite sure but also check if there's 5V DC on board connector P5/1 and P5/3 just to make sure that the correct voltage is being supplied by the board. The power needs to be connected to check this
If you find the problem and it is a faulty part that needs replacing, here's the parts list that is useful.
Locate the wanted part, in the list and note the part number that is shown with it. Search online for the part number only to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Kory 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 21
总计 321
