Backlight problems with LED tv
hi all. I have a sinotech 32 inch led tv. The tv had a backlight issue and I left it for over a year. Got new backlights yesterday and I noticed a few off things.
Firstly the led strip is not the same length as the original strip, the bulbs are slightly off or on the side so creating a problem when the bulbs need to sit on the reflector sheet. At maximum only 4 or the 6 fit.
The second problem is that THERE is no difference with the new lights, when switch on the tv the lights flash and then go off. When I shine a flashlight on the screen I can see the tv is on and there’s audio on the tv when I increase/ decrease volume.
At this point I’m lost as to what could be the issue, anyone with an idea please help. Should I return the strips and find exact ones or is the design of the strips inconsequential? I’ll try uploading a pic
3条评论
That brown cap at the top looks to have a bit of swelling.
由 Ted 完成的
Would it be a bad idea to puncture holes on my reflector sheet so to accommodate the new strips’ lining and then patch the gaps with another piece of sheet from an old tv? I’m asking cos these strips took me a while to get a hold of and it might be a bit difficult to find exact ones. This was the closest I could find to the original strips and the manufacturer said the don’t have them anymore
由 Godfrey Mokwena 完成的
@godfreymokwena you can always try. We do not know enough about the connections on your power board. If it has an error detect circuit it may not work. You always want to fix any known errors first. Replace the faulty capacitor first.
由 oldturkey03 完成的
