跳转到主内容
加入维修社区 - 创建账户
MacBook Air 13英寸机型的维修指南,支持手册,以及疑难解答信息。
21 Cycles - Check Battery / Service Notification
I have had this battery sitting here for maybe 2-3 months unused. It has just 21 Cycles and shows 83% capacity, is not deformed or swollen in any way - Is this still OK to use or just needs some power cycles to maybe boost it up? (OS Clean Install of 10.11.6 just now & all the software updates, nothing more, except our friend CB). It was previously just my testing battery for units that had either a dead battery or no battery at all and was OK before.... weird.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
6条评论
@oldturkey03 Yes I am running it down with a video on repeat..... 1st step
完成的
@livfe let us know what you find out :-)
完成的
@livfe I'd try to calibrate it Battery Calibration and then re-check in a few days.
完成的
@oldturkey03
It is now up to 100% and normal condition but it drains really fast :(
完成的
@livfe I wonder if it's the battery. Use an ammeter and see how many amps it pulls.
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
I did the battery calibration 2x and it went from 84% to 99.4% but still displayed the Check Battery / Service Recommended notification.... then I deleted the com.apple.powermanagement.plist and restarted.... Looks good now :)
This would have been the same result on any 13" MB Air model although I completed the task using a 2011 model just in case the battery did harm in its original state. Just to be safe.,
UPDATE 10/05/25 - 23 Cycles 100% Heath reported :)
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
livfe 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 86
