跳转到主内容
加入维修社区 - 创建账户
Craftsman 917.271551 是一款乘用割草机,配备 15.5 马力发动机。本页面提供了关于该型号的维修及更多信息。它拥有 1.25 加仑的油箱容量、多种地面行驶速度,并具备 3 安培充电系统和 28 安时 (Ah) 电池等特性。
Where is the fuse?
The manual says the fuse is behind the dash but I can't find it, and does not show where it is. After we disengaged/reengaged, the tractor no longer works (we needed to move the tractor manually out of a small ditch). When turning the ignition, we do not hear a clicking sound. Replacing the solenoid didn't fix the issue. The battery is good. We haven't yet checked the fuse because we can't find it. Would appreciate any help. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi @pclee001
Do the headlights work OK when you turn the ignition switch to the lights position?
If they do then the fuse is OK.
If they don't then the fuse may have blown. It's a 20A blade type fuse part # 175158 (examples only)
On p.31-p.32¹ of the owner manual it shows the wiring diagram and the harness layout for the mower. The fuse connects between the ammeter (if installed) or the B terminal of the ignition switch and the solenoid so it may be just hanging out of the harness sleeve between the two points.
¹ For some reason p.32 is not showing in the manual when I post the manual in the answer so here's an image showing the harness layout. It's used in conjunction with the parts list shown on p.33. The fuse is part #26
(click on image)
这个答案有帮助吗?
得分 2
2条评论:
Thanks, we tested the battery again, followed by the headlight. The headlight didn't turn on. We found the fuse with your image, tested the fuse which gave a 0 / near zero reading on continuity. We will purchase a spare fuse just in case, but not sure what to do next for the troubleshooting since replacing the solenoid didn't work too.
由完成的
Thanks @jayeff, it works now. Turns out the fuse was loose.
由完成的
添加一条评论
添加你的答案
Pclee001 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 41
总计 681
