Is a 1500mAh battery compatible with a 1.24 Ah battery?
I ordered a battery from Amazon based on the device. The battery I got from Amazon is rated at 3.7v, 1500mAh, but the battery in the device is 3.7v, 1.24 Ah.
Are these batteries compatible?
I believe that the replacement battery will "discharge longer" which means it holds more charge. I think they are compatible.
If so, a note should be added about batteries to the guide for Garmin Nuvi 680. Ideally, a link to a battery guide should be at the end of battery guides.
