跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab A9+ 于 2023 年 10 月发布,配备 1920 x 1200 像素 LCD 显示屏,搭载高通骁龙 695 处理器,最高可选 8GB RAM 和 256GB 内置存储(可通过 microSD 扩展),并配有 7,040mAh 电池。
LCD screen Dim Backlight issue
Hi everyone, I'm a computer technician. A customer brought me a galaxy tablet (Galaxy tab A9 plus (SM-X210) complaining regarding very dark screen whilst the tablet still on but you can only see things on the screen under the sunlight or under UV light, which is still very hard to see! However I have replaced a brand new screen and resetting it to factory settings and updated but still the same. Now I know the issue is not the actual screen. I'm assuming the backlight for the LCD screen it is on the motherboard but I do not have the motherboard diagram for this model so I can desolder or replace. I'm not too sure where the component for the backlight is located or what is causing this. thank you in advance. Any help greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @adam49009
Here's some information that may help:
  • Website that has the board layout diagrams (and also the schematics). I'm not on FB or have an account with the site so I don't know how much it would cost.
  • Samsung SM X210 Service Guide so that you can check if everything OK if you get it working. Unfortunately there are no board layout diagrams, troubleshooting flowcharts or schematics in the guide.
  • Samsung Members app used for testing the various functions in the tablet as described in the service guide.
Also just verifying the the LCD panel that you installed is Samsung part # GH81-24554A and not something else just in case it is slightly different as to the wiring connections being used?
LCD display and touchscreen assembly for Samsung Galaxy Tab A9+.图片
产品
GH81-24554A - Samsung Galaxy Tab A9 Plus Display Touchscreen
$57.99
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
Adam 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 11
过去 30 天: 62
总计 1,002
