跳转到主内容
The current line of iPod touch comprises seven (7) different generations.
2619 个问题 查看全部
Disabled for 21,991,488 minutes
i changed my password and i cant remember what i changed it to. i tried putting in all the passwords i could think of it being, and that didnt work because now im locked out. . and it says ipod is disabled for 21,991,488 minutes ... HELP ! i havent been able to use my ipod in MONTHS .
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
danae, try to just hook it up to the computer that you use to sync your iPod. If that does not work place your iPod into DFU mode. Here are some great instructions for that "Getting your iPod Touch/iPhone into DFU mode is somewhat tricky, and it may require some patience/practice because timing is essential to get it to DFU mode and not into recovery mode.
1. First, Open up iTunes, plug in your iPod Touch/iPhone to the CPU's USB port. Turn on your CPU's speaker and make sure it is loud enough that you can hear it.
2. Hold down the Home button (top left for iPod Touch and top right for the iPhone with the screen facing you) and the Power button (located on the front bottom of your iPod Touch/iPhone) simutaneously, until the screen goes black and the device turns off. (past the red slider/slide to power off screen)
3. Now let go of the Power button, but continue to hold the Home button. Your iPod Touch/iPhone should have turned off and the screen should not be on.
4. After around ~10-20 seconds, you will hear a noise (beep/ding) from your CPU as if it had just recognized a new hardware device, now iTunes should recognize it in DFU mode.
5. After iTunes recognizes the iPod Touch/iPhone, let go of the Home button otherwise it will go into recovery mode and you will have to do the entire DFU process over again.
6. You will know when you have put your iPod Touch/iPhone correctly into DFU mode when the display is blank and that you do not have anything on your device.
And you are done, now you can install any iPod Touch/iPhone firmware on to your device via the iTunes SHIFT recovery method." You want to remember that this can erase your iPod, depending on if you restore it on the computer that your iPod usually sync's with. Hope this helps, good luck.
这个答案有帮助吗?
得分 2
添加一条评论
Plug your iPod into the computer with iTunes open, reset the iPod by holding Home and the Power Button down together for about 10 seconds, then release the Power button and continue to hold down Home for another 10 seconds.
That'll put it into DFU mode and bring it up on iTunes ready to be restored.
Then you just redownload all the music you want. And boom, you're golden.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
danae 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 387
