跳转到主内容
这是由索尼电脑娱乐(现已重组为索尼互动娱乐)生产的游戏主机。PlayStation 4 Slim(CUH-2000系列)是比初版PS4更薄的替代型号,于2016年9月7日正式对外公布。
Why when I switch it on it goes off again
It goes again off when I switch it on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Morning from Australia!
PS4's are very well known to fail, and as such there's plenty of video footage documenting what happens & how people fix it.
Just checking, when you say it goes on & off, what specifically does it do? Simply because on & off can be multiple different things on PS4's.
Also, have you tried taking it apart? I know repair shops tell you not to disassemble, however as long as you follow the guides on here you shouldn't break anything & you can try find the root cause of what's going on, if a component has failed on the board.
Let me know when you can :)
完成的
添加一条评论
1个答案
最有帮助的答案
Hi Jordan,
Just to add:
This is most likely caused by 2 things.
1: The power supply. I would replace this one for a new one and see how that goes! It's not that expensive and a great test to begin with. Also easy to replace.
Guide: PlayStation 4 Slim Power Supply Replacement - iFixit Repair Guide
2: The APU. This one is very difficult to fix and requires soldering and some serious soldering skills to get it fixed. You can reflow the APU, which is easy but most of the time temporary. Otherwise you need to reball it, and this is very difficult and requires also some expensive tools.
If you need any guides for this, please let me know!
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 35
