跳转到主内容
数百个光盘驱动器的维修指南。
Repairing optical drives instead of just replacing
Does anyone have advice for repairing optical drives. I have one that sometimes reads a disk but if I try to burn a disk I get errors. I work in an e-cycle plant and we get quite a bit of them and repairing seems like a better option than just replacing.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This question was migrated from https://meta.ifixit.com/Answers.
完成的
添加一条评论
3个答案
已选择的解决方案
@jerrywitherite most common failure for something that you describe would be a weak laser. Sometimes increasing the voltage to the laser slightly by adjusting the trimpots (never do that without a meter or you could burn it out). Ultimately replacing the laser would be the only real fix.
这个答案有帮助吗?
得分 0
添加一条评论
they are so cheep. throw it away and try another.
这个答案有帮助吗?
得分 0
1条评论:
@altonbell40070 the iFixit community frowns upon throwing stuff out just because "they are so cheep". Check on here https://www.ifixit.com/Right-to-Repair to see what this is all about.
完成的
添加一条评论
Charge problem
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jerry Witherite 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 13
总计 123
