跳转到主内容
加入维修社区 - 创建账户
SSL 2 是一款于 2020 年 1 月发布的一款 USB 音频接口。它采用了高质量的元件,并且非常易于使用。
Passive Speaker Output Fried Interface
Hello everyone!
So today I failed to use my brain - the following happened:
I tried to connect my vintage sony Hi-Fi-System to my SSL 2+ interface. Since it only has the red and black connectors for passive speakers as an output, I figured I'd simply make a makeshift cable and connect it to my interface. In the two inputs of my interface I plugged a double mono-jack to cinch cable. At the end of the cinch cable I wrapped around a wire so I could plug it into the output of the Hi-Fi player. It worked for 10 seconds, then a pop came through the speakers as if I had just unplugged them and the interface stopped working. For the most part at least.
What works:
-Power LED is on
-4k Buttons light up
-Gain LEDs work (on startup, shows gain when pushing the 4k button, blinks when dis-/enabling +48V)
-miscellanious buttons (I think)
-USB connection (is recognized by the PC, able to reset and update firmware)
What doesn't work (anymore sadly):
-input (not via mic, not via line)
-output (not via speakers, not via headphones)
What's weird:
-4k buttons glow very bright red when disabled (should be off), when enabled they glow slightly dimmer red
4k button engaged
4k button disengaged
back of the board
Question:
Since part of the electronics seem to still be working I'm hopeful I could try and repair it. However, I lack the knowledge to identify which part might be faulty. Where do I start looking? How do I do it? Is it even doable (maybe too small of a part to replace by hand?)
A few quick inspections don't seem to reveal any obvious faults like undone soldering spots or popped capacitors.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
My SSL2+ worked for 4 years and then stopped working.
I have the same problem as cited above.4K buttons glowing redder in the off position, no sound etc. all lights on board work..🤷🏻‍♂️
由完成的
Hey, did you ever end up finding a fix for this? Exact same thing happened me except the cabling was the exact same as it's been for the past 4 years! Now the 4k leds are lit up exactly in the way you described above and I can get no sound in or out of the device
由完成的
添加一条评论
2个答案
Balanced to unbalanced connection might be your problem.
Depending on the balanced audio device output design and the ability to current limit active devices in the case of output short circuit, the following scenario may develop:
This is clearly not desirable, especially for active device outputs. Permanent damage may occur. If unsure, don’t do it. You have been warned.
read more here
I don't see any signs of magic smoke release, and without a schematic it would be very technical and time consuming to find the problem.
The issue is likely a blown output IC. You would have to figure out which IC that was and scope its i/o to verify.
All this is assuming the problem isn't something overloaded and blown in your HiFi.
这个答案有帮助吗?
得分 0
添加一条评论
After 4 years, my SSL2+ stopped working..
I didn’t change Anything..just stopped
What works:
-Power LED is on
What's weird:
Same problem some other guy had. Is there an easy fix. I seen some schematics and techno talk…
Update (01/13/26)
U need to replace U 27 U 28
IC DUAL OP
AMP LOW
DISTORTION
Ti
OPA1678IDR
Update (01/14/26)
IC DUAL OP
AMP LOW
DISTORTION
Location Decription
SHBJEFF1 U27
IC DUAL OP AMP
LOW DISTORTION
Ti OPA1678IDR
2
SHBJEFF1 U28
IC DUAL OP AMP
LOW DISTORTION
Ti OPA1678IDR
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Emils 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 50
总计 680
