跳转到主内容
加入维修社区 - 创建账户
2000 年推出了全新的车型(代号 XD)。旅行版车型被取消,取而代之的是五门掀背版。自 2001 年起,所有美国市场车型均标配前排和前排侧面安全气囊、空调、电动门锁、电动车窗和动力转向系统。
RPM dial arm off
dial arm on RPM meter popped off. How to remove dash window to fix dial on RPM meter
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
There should be plastic tabs around the edges that can be carefully pried off until the clear window can be removed. But often they will just get broken and you might not even be able to fix the dial anyway. It is usually easiest to find a used one at a junk yard. Depending on where you live, there might be a place that lets you pull the part out of a junked car yourself for cheap. Otherwise I would check Alliexpress, searching for a "Hyundai Elantra XD" or "Elantra 3rd Gen" to help narrow it down. The front fascia trim is not too difficult to remove after you locate all the screws holding it in (there are a couple of hard to see ones above the dials), but it takes a little practice to know how to pop the retainer clips out without breaking any of them. Which is where a junk yard helps as you get to practice on those without the worry. I would buy some plastic pry bars from Harbor Freight or Amazon (super cheap) so you dont tear anything up. They wind up being super useful around the house anyway.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Patricia Geier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 5
总计 158
