跳转到主内容
加入维修社区 - 创建账户
2015 年 9 月 25 日发布的 iPhone 6S Plus 的维修信息和指南。型号 A1687, A1634
Random slowdowns and battery drain
Hello,
I've got an iPhone 6s Plus that's playing up. I replaced the battery on it a while ago after the original failed (was draining too fast even when deep sleeping). I went with the battery sold by Replace Base in the UK. It seemed like they would sell decent replacement batteries.
Unfortunately, while the fast draining on idle has stopped, the phone has other problems now. It will randomly start lagging badly when trying to use it. You can barely tap anything when the lag happens. I used an app to check CPU usage and I see it's pegged at 100%. Battery starts draining rapidly as well.
It could go days without having this issue. It just comes on suddenly and when it does, it makes the phone unusable. You have to connect it to a charger to get the lag to disappear.
The battery seemed fine at 1st, then after maybe a few months this issue began.
Is this a bad battery? I've also noticed that when the phone 1st boots from a no power state, I'll see really low percentage (like 2-4%). After a few seconds, it'll jump to a higher value. It did this from the start, but I ignored it because the phone appeared to be working fine.
This looks like a case of a bad battery to me, but just making sure. If it is a bad battery, does anyone know of a seller that sells quality batteries that don't have problems? I've tried 2 replacement batteries so far and both have had issues. The 1st caused the phone to reboot all the time. The 2nd (the Replace Base one) has the issues I've described in this post.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
i use iparts4u for most of my parts, havent had an issue yet. but it might not even be a battery issue as its a 10 year old phone it could be something failing on the logic board
这个答案有帮助吗?
得分 0
1条评论:
Could be something else. However, I won't really know until a new properly working battery has been tested. Just the issue is finding one that is known to be good and working as it should.
由完成的
添加一条评论
添加你的答案
vCore 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 16
总计 246
