跳转到主内容
加入维修社区 - 创建账户
iO 是 Oral-B 于 2020 年发布的一款电动牙刷。它可以通过蓝牙连接到你的智能手机,并为你提供实时 3D 牙齿追踪功能。其型号通过类型编号 3758 进行识别。包含的型号有:iO Series 7、iO Series 8、iO Series 9 和 iO Series 10。
display not working anymore
I have this issue...my toothbrush io 9 display has stoped working but everything else working fine....i open it an and found water inside...this could burn the display? can it be fixed?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
In my case, the battery leaked and damaged the circuit board. I had to repair one of the traces because it was corroded, and the display is working again. I also protected the board with electronics varnish. I replaced the battery and glued the damaged seal around the toothbrush neck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cristian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 15
过去 30 天: 60
总计 416
