跳转到主内容
加入维修社区 - 创建账户
Blinking red power light
The red power light blinks and the TV won't turn on
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hey there!
First of all, do you have the TV series and model number? It will make diagnosing the problem much easier. However, from what I can tell, a flashing red light indicates a power supply or internal component issue. Try first to check your TV's power cord and your outlet to see if anything is wrong with them. You can also try to run the TV through a power cycle. You can run a simple power cycle by pressing and holding the power button on the remote for 5 seconds, or unplugging the TV from the power outlet for 30 seconds before plugging it back in. Finally, try checking your TV's connections (eg. HDMI, AV).
If all else fails, try to check if your TV is still under warranty and go from there. You can also contact Samsung Support, and they will try to diagnose the problem with your TV. You are also welcome to try to open up the TV by yourself and fix it, but I wouldn't recommend it for many reasons.
Best of luck!
这个答案有帮助吗?
得分 0
添加一条评论
Yes it won’t and I’ve tried many times
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ricardo Figueroa 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 17
总计 297
