跳转到主内容
加入维修社区 - 创建账户
9 月 24 日发布的苹果 2021 旗舰智能手机配备 6.1 英寸 ProMotion OLED 显示屏、全新三镜头后置摄像头系统和 5G。iPhone 13 Pro 是 iPhone 12 Pro 的继任者。
iPhone 13 pro battery replacement
I bought the anti-clamp and iphone 13 pro fix it kit to replace my battery on my iphone 13 pro.
I cannot get an initial gap to appear at the bottom of the display after following these directions:
iPhone 13 Pro 电池更换
After removing the pentalope screws at the bottom of the iPhone, I tried the following process for 2 hours:
Heat the bottom of the iPhone with a hair dryer for 90 seconds, quarter turn the anti-clamp to increase the suction each time, wait for a minute to see if a gap appears but it never did.
There must be a step that isn’t in the instructions.
Specifically, what to do when the following step does not result in an opening gap at the bottom of the display other than try again:
“Wait one minute to give the adhesive a chance to release and present an opening gap.”
I am trying this repair myself because the apple store refused to replace my battery as the top right corner (metal part not the screen) has a few more scratches than they are comfortable with.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
This question was migrated from https://meta.ifixit.com/Answers.
由完成的
添加一条评论
2个答案
If the kit came with a guitar pick like plastic piece, you can try inserting it by pressing it between the frame and the screen (CAREFULLY) with a sliding motion. This can help encourage the phone screen’s adhesive to come loose.
Edit: You may already know this, but just to make sure, if you don’t have a replacement adhesive for the screen, it won’t be dust proof or water proof as it was before.
这个答案有帮助吗?
得分 0
添加一条评论
Heat the phone while pulling, increase pull force but not too much so the suction cup pops off, find the upper limit of the pulling force then keep it.
Then heat the phone at the area you want to pull apart to soften the adhesive, it will soften and pull apart.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
pete k 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 12
过去 30 天: 41
总计 678
