跳转到主内容
加入维修社区 - 创建账户
荷兰制造商飞利浦提供滴漏式咖啡机、全自动咖啡机,以及以 SENSEO® 品牌销售的单杯咖啡机。这些机器经常以 Saeco 或 Gaggia 的品牌出现。
Machine not pulling shots
My Phillips ep 4321 is not pulling shot. Water seems to be going into the tray instead of shots. Steam wand works fine
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
Did you manage to fix it? Having the same problem after cleaning the machine
这个答案有帮助吗?
得分 0
添加一条评论
I had the same issue, check the gaskets on the inside of the machine, specifically the brewing unit(looks like a nozzle with one bigger gasket, that narrows down closer to the tip with a smaller gasket). This is where it usually leaks due to a lot of pressure, that can not be held. The water doesn't go into the brew group (the plastic amusement park, mostly black with a few yellow parts) and goes right into the tray, while the milk steamer works. Lubricating the gaskets also seems to be important. The brew group also has a few gaskets, that do deteriorate. Since the machine stopped working properly after the cleaning, I would check the gaskets and lubrication of the brew group as well. Be careful if you are disassemble the brew group, keep track of the position of the spring and glass bead/ball.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ron G 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 29
总计 232
