跳转到主内容
加入维修社区 - 创建账户
查找 LG LFCS27596* 冰箱的维修及其他信息。这是一款 2019 年发布的机型,具备自动除霜功能,但不配备门上饮水机或制冰机。本页面涵盖了符合 LFCS27596* 模式的机型信息。
CF E code after fan replacement.
I replaced the condenser fan on my fridge when this code popped up. It worked fine for like 24hrs then I noticed the sides of the fridge were hot again and it was throwing the code as well. I unplugged it and let it sit for about 10 minutes then plugged it back in and spun the fan my hand and it started working again. Now it is off again when I checked it about 16hrs later. Any ideas on what would cause this because I am out of ideas. Thanks for your time
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @dylanmcguire
A CF E error code indicates a problem with the condenser fan or condenser fan operate circuit.
Here's the start of the CF E troubleshooting section of the service manual that may help.
It the replacement fan is the problem, search online for EAU63923602 to find suppliers that suit you best. This is the part number for the condenser fan and it should be printed on the fan itself if you wish to verify that it is the correct one.
Ensures optimal airflow across the condenser coil in LG refrigerators by rotating when activated.图片
产品
LG Dc Motor Assembly - EAU63923602
$93.99
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Dylan McGuire 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 26
过去 30 天: 74
总计 924
