跳转到主内容
加入维修社区 - 创建账户
Making grinding noises while washing
Here is a video of it grinding away but not actually washing. What is the issue? https://youtu.be/ZD7A3QeGefw?si=J18Ic7dk...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hi @jacobblaylock
Does it also do this if you run the washer with no load in it?
Don't know Samsung washers that well but try running the diagnostics (select Run diagnostics on a top load washer) and check if any error codes are shown, especially error code 3C (washing motor defect).
If there are any error codes being displayed, here's the service manual that may help. Go to p.28→p.30 (p.30→p.32 of 37 pdf) of the manual, to find the meaning of the code. On p.31→p.34 (p.33→p.37 pdf) of the manual, you'll find information what to check for each error code.
If you find the problem and it is a faulty part that needs replacing, here's the parts list that is useful. Locate the wanted part in the list and note the manufacturer's part number that is shown with it. Search online for the part number only, to find suppliers that suit you best.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Jacob Blaylock 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 27
总计 249
