跳转到主内容
加入维修社区 - 创建账户
A1706/EMC 3071—于2017年6月上市,这台13''MacBook Pro以可升级至3.5Ghz酷睿i7动态超频至4.0GHz的Kaby Lake处理器为特征。
How to fix/replace component underneath the key piece?
My E key has been missing for a while, but the component underneath still worked when pressed. Now, it’s no longer working. Can I replace just that break, or do I need to order a whole keyboard? TIA
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
You should be able to replace the scissor mechanism as well as the rubber bumper. Here is a source for the needed parts TheBookYard - MacBook Pro keyboard parts click on the image to dig into the different caps and other parts.
这个答案有帮助吗?
得分 0
添加一条评论
@valeriasan26150 here is the A1706 Keycap Replacement procedure. Take a look at page 2 for the explosion drawing on your keys. Although keycaps can be replaced, the butterfly and switch housing cannot. A damaged switch housing or butterfly requires replacement of the entire top case.
这个答案有帮助吗?
得分 0
1条评论:
Sorry OT I’ve replaced them using this part Keycap Mount and Dome - Alphanumeric
完成的
添加一条评论
添加你的答案
V santi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 132
