跳转到主内容
加入维修社区 - 创建账户
2008 年推出的上网本;型号 ZG5 AOA150-1691;8.5 英寸屏幕;1.6 GHz N270 英特尔凌动处理器
How do I reinstall display adapter
i accidently uninstalled my display adapter. how do i reinstall it windows boots up but after it does my screen goes blank
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
How'd it go? Any luck?
完成的
添加一条评论
3个答案
最有帮助的答案
Alright, so this is what I've found.
You should be able to restore your deleted display adapter through the Acer eRecovery Management system.
You can access this system during the boot up process, which will bypass the need for the display adapter to load, by pressing the hot key (Alt + F10) which will start the Acer eRecovery Management system.
Reloading your display adapters from this system is your best option.
Let me know how it goes.
这个答案有帮助吗?
得分 1
添加一条评论
You should be able to go into Safe Mode. So do it from there. After going to Safe Mode, go to Computer Management and Device Manager to update the display driver.
Ask again, if you have any problems.
Max
这个答案有帮助吗?
得分 0
添加一条评论
hope this can hep m too. I just reformatted my acer aspire one notebook, after restarting.. the laptop stills power on but no display comes up. Thanks in advance buddy, i'll try your suggestions. I have tried some other tricks from other sites but did not worked.
I will inform you soon once I solved my same issue. Thank you!
I'm ronie cambronero from Philippines +639196029417. A one year as computer technician.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
jeromie 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 11
总计 1,602
