跳转到主内容
加入维修社区 - 创建账户
Logitech Rumblepad™ 2 是一款 21 世纪 20 年代中期发布的支持震动反馈的 PC 游戏手柄。它配有 2 个模拟摇杆、一个十字键和 12 个数字按键。
My buttons are automatically working
button are working automatically by their own and and the right analog stick is also working automatically. Also i cant set any keymapping it automatically fetch keymapping and starts working by its own
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
1个答案
Inspect and clean around the buttons, it can do that if its dirty or if there's a tiny bread particle or something stuck in there, it also could be because the usb plug is falsy (common problem for this controller). Basically when it disconnects and reconnect randomly(because the usb plug's is falsy). the last button u pressed will be stuck there, so if u pushed analog stick "up" for example and then disconnect and reconnect, it will read it as the analog stick is pushed up even tho it's not, in that case, just disconnect and reconnect without touching any button.
if none of this is your problem,Close any keymapping software.
  • Check Steam > Settings > Controller > General Controller Settings, and uncheck options like “Generic Gamepad Configuration Support” temporarily to see if behavior changes.
  • If a keymapping profile is auto-loading, delete or reset it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Different Learning Centre 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 31
总计 432
