跳转到主内容
加入维修社区 - 创建账户
2.2 GHz(Turbo Boost 最高可达 3.4 GHz)或 2.5 GHz(Turbo Boost 最高可达 3.7 GHz)四核 Intel Core i7 处理器,配备 6MB 共享三级缓存。
iFixit battery kit compatibility
I have an iFixit battery replacement kit for a 2012/2013 MacBook. Will it work in a Mid 2014 model?
Battery: NuPower Battery for 15" MacBook Pro Retina Mid 2012 to Early 2013
Laptop: MacBook Pro (Retina, 15-inch, Mid 2014)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
If we look at the batteries specs
Late 2013-2014 - Battery Model #A1494
Watt Hours - 98 Wh
Voltage - 11.26 V
Milliamp Hours - 8700 mAh
Mid 2012-Early 2013 - Battery Model #A1417
Watt Hours - 99 Wh
Voltage - 11.26 V
Milliamp Hours - 8800 mAh
They are clearly a bit different, they are also physically different. Why don’t you exchange the battery for the correct one. Give the iFixit Store a ping, I’m sure that can exchange it.
这个答案有帮助吗?
得分 0
2条评论:
Thanks, Dan
The specs you posted are not significantly different. But, from your comment I looked closer at the two laptops. The batteries are almost identical physically but the connectors are not placed in the same spot on the battery. So, you're right the battery won't fit properly.
Oh, the battery was actually purchased in 2019 but never used. Kind of late for a return! :/
由完成的
@greg43696 - Sorry I meant the battery was different.and wouldn’t fit property.
由完成的
添加一条评论
添加你的答案
greg 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 15
总计 247
