Why is the usb plug not working properly?
My usb plug is not recognizing power sources and computer connections; and the battery is lasting less and less
is there anything to do?
@carole50859 could be some dirt et. inside the plug. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out.
If that does not work it may be time to replace the Sub board (daughter board or charging board). since iFixit does not yet have a specific guide for that, use the one from here It was written in Spanish, so use a browser that will translate it for you (if needed).
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this. Repair is War on Entropy!
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 145
