跳转到主内容
加入维修社区 - 创建账户
2.2 GHz(Turbo Boost 最高可达 3.4 GHz)或 2.5 GHz(Turbo Boost 最高可达 3.7 GHz)四核 Intel Core i7 处理器,配备 6MB 共享三级缓存。
Touchpad not found after replacement
Hi all -
Original symptoms were short battery life and touchpad physical clicking not working. I bought a replacement battery and touchpad.
Battery was definitely bulging and putting pressure on the touchpad. I swapped out both and when booted back up - no mouse movement or clicking at all from the touchpad. External mouse works fine, so I went into system preferences and then Touchpad. It said "Touchpad not detected" or something along those lines and had a spinning circle indicating that it was searching for bluetooth touchpads.
So I opened it back up and swapped in the original touchpad - mouse movement but no clicking. But still, system preferences says it doesn't detect a touchpad (I was hoping to at least turn on tap to click.)
So, what am I missing? Is there some extra step to set up the touchpad with the OS? Does the lack of movement on the replacement pad mean that it's DOA?
Thanks for any help!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
Did you also replace the trackpad cable with the trackpad MacBook Pro 15" Trackpad Cable (13/14) the cable holds the interface chip which can get damaged.
这个答案有帮助吗?
得分 1
4条评论:
Yes, the new trackpad came with a new cable. I haven't removed the cable from either pad, just disconnected from the logic board
由完成的
@agitatedgopher - Try replacing the cable with a fresh one. I’ve hit a few bad ones as I suspect the chip is a bit static sensitive (ESD).
由完成的
Oh, I forgot to come back here, but yes, that fixed it! Went to a mac repair shop, showed them what I needed, the guy in the back who knew everything got me a cable, and I forgot what they charged me for it, but it's working happily now.
由完成的
@agitatedgopher - That's Great! Don't forget to score and accept the answer so others find the solution. Thanks!
由完成的
添加一条评论
最有帮助的答案
Have a look at the MacBook Pro 15" Retina Display Mid 2014 逻辑板更换 & check step 25 for the touchpad connection to see if it is correctly seated. This maybe your issue.
这个答案有帮助吗?
得分 1
2条评论:
Well, that was the first thing I tried, reseating the connector. Still no change. Then I reinstalled the original pad and got mouse movement, but it still doesn't show up in preferences. Then I switched back to the new pad and it's still no movement and not showing up in preferences
由完成的
@agitatedgopher Hmmmm.... Maybe @danj can give some thoughts....
由完成的
添加一条评论
添加你的答案
AgitatedGopher 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 25
总计 285
