跳转到主内容
加入维修社区 - 创建账户
Xbox One 手柄在2016年随着 Xbox One S 的推出而问世,并增加了对 Windows 10/11 的蓝牙支持。 该手柄修复了 Model 1537/1697 手柄上的许多设计缺陷,更加可靠。该手柄已被改进版 Model 1914 手柄所取代。
Xbox says controller is disconnected
My Xbox continually says that my controller is disconnecting, even though the light on the controller is still on. I’ve used 3 controller, multiple batteries. I’ve used the USB port in the xbox to charge the controller and it still happens. I’m not exactly sure if this is an Xbox issue or a controller problem. I ordered a new xbox controller and its currently on the way so maybe that will fix it. But any idea will be greatly appreciated. Thank you.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Can you confirm if you are connecting this to an xbox console or PC please?
Also, can you confirm if what you are using to connect the controller, is it always wireless or do you ever use a USB type cable?
Also, are you using battery packs, as in a pre-made after market battery rather that the traditional AA size standard batteries?
Thanks in advance for your answers :)
这个答案有帮助吗?
得分 0
1条评论:
It is an Xbox one console. It is a wireless controller but i have used the USB port in the console to charge the controller and still no luck. I mainly use battery packs but even with the issue I’ve been having it happens even when I’m using packs or AA batteries. Thank you!
完成的
添加一条评论
添加你的答案
Nathan Tarr 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 262
