跳转到主内容
加入维修社区 - 创建账户
A1708/EMC 3164—在2017年6月上市,这台入门级MacBook Pro保留了它的实体功能键(相对于OLED Touch Bar)。
stuck on apple logo
Hi all, I have a MacBook Pro A1708 which is stuck at the apple logo when booting. Nothing more happens. I have tried all the key combinations for nvram, smc, diagnostics, safe mode, recovery. Nothing seems to do anything. At some point the smc key combination made the fan blow at max speed but that's it. Any ideas what else I can try?
Update (04/03/25)
hi all, update here, Apple Store did not diagnose it more. I got it back, removed the SSD to try and see if I get something else. Unfortunately no, still stuck on Apple logo nothing else happens. It should give a question mark right now not? So if it's not showing the question mark probably something else is broken? Any ideas what to do next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论:
It does take a bit of time to get to the missing OS state (blinking ?) so in 3 minutes it doesn’t respond the logic board has a deeper issue.
由完成的
It switches it self of after about 30 seconds. So I presume it is a motherboard issue? Any idea what to do next?
由完成的
@alexandros04 - Sadly, this ready needs someone with deeper skills and tool to isolate out what’s going on. Not enough info to tell you what has failed or why. Where abouts do you live? Let’s see if we can aim you to a shop with the skills. Just give us your country and nearest major city.
由完成的
I am a bit capable, working with multimeter, soldering, reflowing. Not an expert but willing to learn and try. You think you could guide me? Otherwise, I live in the Netherlands, nearest city Utrecht.
由完成的
@alexandros04 - Sorry I don’t know of anyone in the Netherlands, the nearest shop I can recommend is just outside of Liverpool in the UK TheBookYard. As to helping you remotely that really doesn’t work at this level of repair. Besides, you will still need access to the parts.
由完成的
显示更多的1条评论
添加一条评论
2个答案
Have you tried running the builtin Diagnostics to see if an error pops? Restart and this time hit and hold the D key to enter. Let us know if you get any errors.
这个答案有帮助吗?
得分 0
12条评论:
doesn't do anything when I do that unfortunately.
由完成的
@alexandros04 Do you have access to another Mac to try target mode to at least recover any important files, next step would be to try to do a clean install, if the issue still persists then I would look to there being a faulty SMC. You could also try booting externally if that is a impassibility to narrow it down.
由完成的
@livfe - the system is not even getting into Diagnostics. This is a deeper issue
由完成的
@alexandros04 - You could try reseating the SSD, do you have the needed tools to open the system following this guide 2017年晚期带功能键的13英寸MacBook Pro 底壳更换
If that fails you’ll need a new SSD drive which already has the OS installed to replace yours. As you can’t even get into diagnostics limits what you can accomplish using the Startup commands Mac startup key combinations
由完成的
This maybe related What is causing this to be so slow & can it be fixed? and the problem was the SMC, it would be worth checking the data lines & current sense resistors also just in case. SSD failure would indicate a question mark folder?
由完成的
显示更多的7条评论
添加一条评论
Try Internet Recovery (Cmd + Option + R on boot) to reinstall macOS. If that fails, create a bootable USB installer. If still stuck, it could be a hardware issue—check the SSD or logic board.
这个答案有帮助吗?
得分 0
1条评论:
unfortunately nothing happens
由完成的
添加一条评论
添加你的答案
Alexandros04 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 44
总计 701
