跳转到主内容
Support for gas-powered and electric golf carts, sometimes referred to as golf cars or club cars after the Club Car Golf Cart brand.
494 个问题 查看全部
looking for a diagram for Club Car Golf Cart rear brakes
My dad asked if I could find a diagram on the rear brakes for his golf cart.He has the wheels and drums off but can't figure how to remove the brake shoes.I haven't looked at it yet because they live 65 mls away but going to visit this weekend so I'm hoping to be able to have some good news when we get there.I've looked on line and have only found discripted advice,no diagrams.It sounds like it should be easy but it would help to have a diagram....Thanks
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
What year is it, and is it electric or gas powered?
完成的
Electric ds 89
完成的
添加一条评论
1个答案
已选择的解决方案
Mike, you did forget to mention which Club Car it is. The brake diagram I posted is for 86-93 model DS. Of course I am certain it will also describe others. Here is what the service manual for that specific year says:"
Brake Shoes Removal
1. Loosen the brake cable at the equalizer and turn the brake shoe adjusting screw (5) outward to reach the brake shoes (6) until the brake drum (9) clears the shoes.
2. Remove wheel and brake drum
3 Remove shoe retaining clip by rotating 90 deg. while holding pin with needle nose plier.
4. Remove shoes and springs as a unit by securely holding one shoe and pulling the opposite shoe out of the grooves in the actuator.
If you need something more specific on the brakes, let us know. hope this will help you and your dad. Good Luck.
这个答案有帮助吗?
得分 4
4条评论:
Thanks it's an electric and I have no idea what yr it is.My dad got it used after his other died.I think this diagram will help from what he's said the brakes are similer to the ones on a car.I'll print this and take a look when we go visit this weekend.He is 75 and a cancer surviver and still trying to do as much on his on as possable but this has him a little stumped...Thanks again...
完成的
Sounds good Mike. Just let me know, I might even have the service manual for the Club Car. The brake assembly is the same for the electric and the gasoline powered cart. All the best to you and your Dad, and never give up :-)
完成的
@oldturkey03
I need detailed info. on "Braking System" of electric powered golf cart.
please provide the same as soon as possible.
完成的
I have a 2004 club car ds, it does have a lift kit on it. The brakes have recently started locking up and pushes the pedal back hard on your foot. It had a bit of a scrubbing problem so I added some washers as spacers, however this was done about six months ago, the grabbing has just started. U bolts on axle are tight. Any other suggestions? Thanks
完成的
添加一条评论
添加你的答案
Mike 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 22
过去 30 天: 69
总计 29,513
