跳转到主内容
加入维修社区 - 创建账户
这款笔记本电脑专为学校使用/轻度游戏用途而设计。
Why is my pc slow?
It's very slow in literally everything.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
I have a friend who has the same issue and he told me it has to do with his RAM. Try replacing your RAM. Another issue would be if your pc overheats
这个答案有帮助吗?
得分 0
添加一条评论
It could be due to many factors: insufficient ram (this laptop only supports max at 8GB which is the minimum requirement for ram configuration in 2025), a newer version of window could possibly slow the laptop dramatically because of incompatibility. Other factor could make this laptop model slow include heat and hardware limitations (CPU and GPU are not up to date standard). Make sure to double check some of the problem above on your laptop to find out which problem you may have.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dan Miks 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 206
