跳转到主内容
加入维修社区 - 创建账户
三星在 2024 年 1 月 17 日举办的“Unpacked”发布会上正式发布了 Galaxy S24 系列。Samsung Galaxy S24 是 2024 年该系列的基准旗舰机型。
Screen + frame replacement Samsung S24
Hello!
I replaced the [screen+frame] unit on my S24, and the buttons ont the side of the phone don't work anymore. The screen works when I put the phone on charge but I only have a logo with the circle and the little lightning for a few seconds.
Can anyone help me to fix this please?
Thanks a lot :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Is the phone charging? I know you see the lighting logo but, does the green circle increase? If so, we know the phone is atleast taking a charge.
The S24 replacement part with frame usually has the power button and volume button built into, so you dont have to transfer them. I would check to make sure though. Usually, you can tell if the buttons click properly or not.
这个答案有帮助吗?
得分 1
2条评论:
Thanks for your answer! No, the green circle doesn't increase. I had to transfer the buttons but I did it well and easily. The buttons click properly.
由完成的
You're welcome. I would double check all the connections such as the battery and charge port. The fact that the battery isnt charging leads me to believe the charge port isnt being seen by the mainboard. Once the phone is taking a proper charge and you see progress on the screen that the phone is charging, I would test the power button again.
由完成的
添加一条评论
添加你的答案
Haha Hihi 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 548
