跳转到主内容
加入维修社区 - 创建账户
How to fix P0403?
How to fix the P0403 error code Vitz/Yaris 2005 1KR-FE engine?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
P0403 is an OBD-II code that indicates a malfunction in the exhaust gas recirculation (EGR) system. The EGR system reduces nitrogen oxide emissions and cylinder temperatures by recirculating exhaust back into the engine.
I just had this problem on my Highlander. The EGR system is a closed system. Leaving the gas cap loose or a defective cap will cause that DTC.
In my case, a squirrel decided to dine on the hose and opened it up the system. Because it was open for a long time, it sucked dirt into the system and caused other parts to fail. The hose on the Highlander is part of the gas tank, so the tank needed to be replaced along with a pump and a valve. Fortunately, I have comprehensive insurance which paid for it - about $8000. altogether.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Hélder de Castro 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 22
总计 478
