跳转到主内容
加入维修社区 - 创建账户
Cuisinart 咖啡机的相关指南与维修信息。
Level indicator float loose
The float that indicates coffee level is not working and may have come unattached. It is loose and moves freely when I checked
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I had this problem. I managed to disassemble the reservoir to inspect the float mechanism only to find that the mechanism, being quite flimsy, had been broken, probably by my rough attempts to clean the area by sticking a sponge in the gap inside the reservoir. If you want to take the thing apart, turn the reservoir upside down. There are two Phillips head screws at the bottom of those two holes in the bottom of the reservoir. Once you get them out, turn the reservoir over (right side up) and find the plastic 'clips' under the rim of the reservoir and gently pry the top of the reservoir loose from the main body. You should have access to the float mechanism at this point. Mine was unfixable so I bought a new reservoir from Cuisinart for $35. Love the coffeemaker! Here's a link:
https://www.cuisinart.com/coffee-on-dema...
Good luck!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
J Mitch 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 8
过去 30 天: 48
总计 1,089
