跳转到主内容
加入维修社区 - 创建账户
型号 A2159,EMC 3301。入门级 13" MacBook Pro 的一次更新。提供银色和深空灰色两种颜色。发布于 2019 年 7 月。
A2159 no display after boot
Hi all,
Im experiencing an issue with my MacBook Pro 2019 A2159. After replacing the broken display with a new unit (labeled A1949), the following behavior occurs:
Normal Boot:
The Apple logo appears at startup, but a few seconds after opening the lid (or at the login window), the display goes black only the backlight stays on. The touch bar remains functional and can adjust brightness
Safe Mode & Recovery:
Both modes display the screen correctly, with no issues observed.
Tests Performed:
Reinstalled macOS (clean install)
Reset PRAM and SMC
Ran Apple Diagnostics (no hardware faults detected)
Disconnected the camera
Has anyone seen similar behavior or have any suggestions? Any insights would be appreciated.
Thanks in advance!
Update (02/08/25)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
2条评论:
@andreanavarra - Where did you buy the display? If it’s new virgin display you will need to calibrate it via Apples paywalled tool, a used display will work but you do loose TrueTone.
由完成的
I thought the calibration was only on the M series. I haven't read anyone online who had this problem. I also updated to Sonoma with no results. As soon as I open the lid it works for about 5 seconds and turns off. I would like to know what happens that makes it turn off, I doubt is not the sleep sensor because the touchbar is on and in safe mode the sleep works correctly.
由完成的
添加一条评论
1个答案
The issue is the source of the display, this series from the display factory didn’t have the camera firmware loaded which was done during the build of the system in the assembly process. So a virgin display won’t work properly. While the term calibration can be misleading it’s what Apple calls the step.if you got a used display the firmware would be present.
the M Series also need calibration due to parts serialization.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
andrea navarra 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 28
总计 332
