跳转到主内容
加入维修社区 - 创建账户
任天堂的 Game Boy Advance(GBA) 掌上游戏机 于 2001 年发布。维修它只需要常用工具,而且不需要电热工具处理。
Gameboy Advance - doesn't turn ON (ON/OFF switch cleaned)
Hi guys!
I have this old GBA which doesn't work and I decided to try to repair it. There was battery leak inside and the power button was damaged. At first the gameboy didn't turn at all. I disassembled it, opened the power switch, cleaned it up and I now it's still not working (haha) but there is som led blinking for a while and just a milisecond buzzing sound from the speaker.
I have also tried to jump the switch ON pins with a wire to bypass the switch but the result was the same.
I have also checked continuity from + -> F1 -> 101 -> Q5
No screen at all...could you please help me what should I try next?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi there!
The only advise I can give you is to replace the ON/OFF power switch.
If this didn't worked, please check the traces there. It's possible that the traces and/or the solder pads are damaged and causing this.
As far as I can see, this is related to the power switch or it's traces or solder pads...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
wiston 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 32
总计 319
