跳转到主内容
加入维修社区 - 创建账户
Bostitch CAP1512-OF 空气压缩机是一款便携式电动设备,配备 1 马力感应电机、无油泵和 2.6 加仑储气罐。它专为驱动各种气动工具而设计,适用于小型装修和木工车间等场景的间歇性使用。本页面提供该产品的维修信息和详细介绍。
Pressure Shut off Switch
The pressure shut off switch was not working. I replaced it and the compressor still does not shut down. Any ideas what else to check?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Is there a leak? Does the pressure build up enough to shut it off? Is the new one wired in correctly.
If it is wired right, and the pressure builds up, and it is set to a proper pressure, and it operates, it must shut it off.
A leak, keeping the pressure down, or wrong wiring (for a new assumed functional switch) would be the only thing keeping it from shutting down.
The moral of this laundry list is, you should post everything you see about the problem.
这个答案有帮助吗?
得分 1
1条评论:
No leak. Pressure goes to 150+ psi. As far as wiring, I assume that is a simple on off switch with the position of the two wires not mattering. I wish I had a way to test the new switch.
由完成的
添加一条评论
添加你的答案
Gil Coale 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 33
总计 320
