跳转到主内容
加入维修社区 - 创建账户
2016 年 9 月发布。 型号为 SM-G610。
How to clean speaker
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
You can use 99.9% isopropyl alcohol to aid in clearing out debris from the speaker. Just make sure you turn off and unplug the device then after cleaning leave it for an hour to make sure that all of the alcohol has evaporated (you can use the heat of a hairdryer to help).
这个答案有帮助吗?
得分 1
添加一条评论
To clean the speaker, first turn it off and unplug it. Then, gently wipe the outside of the speaker with a soft cloth or special speaker cleaner. Do not use water or harsh chemicals, as this can damage the speaker. If dust accumulates in the small holes, it is best to clean it with compressed air or a soft brush. Regular use of speaker cleaner will improve the sound of the speaker and increase its lifespan.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Madan Mistry 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 31
总计 1,235
