Will not stop running
I replaced the start relay for the compressor and the fridge has gotten cold but has not stopped running and its been over 24 hrs. i have also tried to adjust the temps to see if it would shut off an no luck. Any advise would be nice.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Hi @adamdavis24182
What is the full model number of the refrigerator?
Asking because there are 40 models beginning with 106.5897... and they're not all wired the same.
What are the actual temps in both compartments? Use a thermometer to verify in case the display temps aren't correct for whatever reason.
Why did you have to replace the start relay?
完成的
添加一条评论
